Drop spindles
If you decide to install drop spindles, make sure you check for shock end clearance in case you have a flat. The 91-96 Roadmaster with 2 inch drop spindles will allow the shock to hit the ground if you have 15 inch wheels. Minimum wheel size should be 17 inch with the 2 inch spindles.
| All times are GMT -5. The time now is 04:08 AM. |
