-   Roadmaster (https://www.buickforum.com/forum/roadmaster-41/)
-   -   ignition key (https://www.buickforum.com/forum/roadmaster-41/ignition-key-8330/)
memphis Aug 11, 2019 03:27 PM
ignition key
Anyone have any idea why my 1993 Roadmaster key won't turn to accessory position?
All other positions are fine but the key stops at lock position.
Key is not stuck in and has no other problems, just wont turn to accessory
Fred Kiehl Aug 18, 2019 07:22 AM
I am not sure any of them do. I believe mine does not in my 91 or 92 OCC. The only catch to that is the 91 has a 93 FW column in it, and the 92 has a 91 column in it.
memphis Aug 18, 2019 07:39 AM
Thanks Fred
Are you like me. Cant listen to the radio when parked? Is there a solution?
Fred Kiehl Aug 18, 2019 07:49 AM
I seldom sit in my car when it is parked, so I never thought about it. My cars are for transportation, I go from one place to another, and do my business, then go to the next destination. The only times my cars sit still with me in them is when I am at a traffic light, or when they are being repaired.
hanky Aug 18, 2019 02:54 PM
Sometime if a key is worn or not cut right it will come up with problems like that.
If you have another less worn key , do you get the same result?
memphis Aug 18, 2019 05:13 PM
My car is for chasing girls. I sit parked quite a lot.
hanky Aug 23, 2019 05:32 AM
The darn cobwebs under the car gave me away too !
memphis Aug 23, 2019 08:29 AM
Nice one!
