-   Roadmaster (https://www.buickforum.com/forum/roadmaster-41/)
-   -   95 that suddenly won't turn over starter. (https://www.buickforum.com/forum/roadmaster-41/95-suddenly-wont-turn-over-starter-6320/)
Triggerhorse Aug 11, 2012 02:16 PM
Hello everyone. I am in a bind.I tried to start my 95 Limited sedan up and all I got were dash lights(no sound at starter). After many tests ie: Starter, battery, vats system (all check out fine) I pray I am not stuck with: The dreaded Tow to a GM dealer. I should add that I jacked her up and tested the starter at the solenoid. The car started and ran for about a couple seconds then shut off like someone turned the key off. I did this about 4 times more but everytime it started and ran 2-3 seconds then shut off-- even when I had someone pump the accelerator after the engine started but it still instantly:( shut off.
No pass key light illuminating -ever! Any ideas like-- What would you do??
hanky Aug 11, 2012 04:30 PM
You should have a second key to use . Try it ! Key could have lost some info.
Triggerhorse Aug 11, 2012 07:22 PM
re
I have done that and the vat security checks out.
Triggerhorse Aug 12, 2012 08:58 PM
Finished?
I worked for 2 hours today trying to figure this out-- Failure!!:o
hanky Aug 13, 2012 05:14 PM
There have bee some reported problems with the ign switch assys. Might want to confirm it is completing the circuit to the rest of the vehicle.
Triggerhorse Aug 19, 2012 12:52 PM
Cannot solve but must be electrical
After 2 years--Suddenly my power trunk open switch works-- coincidence?:confused:
hanky Aug 19, 2012 04:33 PM
IMO I don't believe they are related.
Triggerhorse Aug 20, 2012 10:12 PM
Solenoid??
:confused:How about this? Maybe the solenoid needs to send a message back to the ignition that the circuit to the starter is still in place or the security system shuts the fuel off. Remember that the cuicuit is complete until I pull the screwdriver :confused:jump back off when it started underneath it.
hanky Aug 21, 2012 02:07 AM
The vat system typically blocks power to the starter solenoid and fuel injectors. Sounds like it is doing that when it should not.
Triggerhorse Aug 21, 2012 11:56 PM
Newrockies Pro ByPass module
:confused: I believe I may be a good candidate. Any feedback would be greatly appreciated.
