-   Riviera (https://www.buickforum.com/forum/riviera-31/)
-   -   Brake Pedal sticking (https://www.buickforum.com/forum/riviera-31/brake-pedal-sticking-8095/)
michaelo Sep 6, 2018 07:15 AM
Hi from Germany! My Riviera has this problem: Sometimes (engine on) the brake pedal sticks after hard braking and comes loose again after a few meters of driving. Brake booster and master brake cylinder are new. I did the brake booster test (engine off, some steps on pedal until hard, engine on, pedal goes down a few inches) and this was ok. When the pedal is stuck (at idle) and when I remove the valve from the brake booster the pedal comes up! There is a lot of vacuum on the hose and the valve is ok. I exclude problems with calipers, brake hoses, because when I use the brake with the brake booster valve disengaged everything is ok (with the exception of course that I need much force to brake). I would very much appreciate every hint what I can do next and how to solve the problem.
Regards
Michael
hanky Sep 6, 2018 11:10 AM
You know this question was coming, did you have the problem before replacing the master and booster?
There should be a vent to allow air into the booster when vacuum is applied to the other side of the diaphram. Check to make sure that vent is not blocked.
