How would I check the regulator?
With the key "on" or the engine running, pull the vacuum line off, and if there's and gas leaking (or smell of gas {i think}), it needs to be replaced.
ok Ill check that.
Thanks |
Ok checked it with the car running and no smell or gas leaking from it.
Okay, thats good. You can try to replace the fuel filter next. Its only a few dollars, and not overly hard to change.
It was the first thing that was done.
Okay, well I am out of ideas. :(
I am too that's why I came here. Thanks for the help.
Have you checked the breather tube? Its a vacuum line that runs from the intake to the back of the motor.. mine was off at the motor, and it caused a bad idle.. could be worth a check.
Yes I have checked it too.
