-   -   Torque Rear Strut Shaft Nut @1990 (https://www.buickforum.com/forum/regal-1973-2004-23/torque-rear-strut-shaft-nut-%401990-6387/)
derwochi Oct 10, 2012 01:51 PM
Hi,
I'm looking for the torque spec. of the rear strut shaft nut on a 1990 2 door Regal 3.1 (the ones inside the trunk).
Any idea?
Thanks Martin
SwitchPitch Oct 11, 2012 01:41 PM
The big center nut on the top on the later models is 55 lbs.
Doesn't sound like much for such a big nut, but it seems right for what it's got to do.
Again, unfortunately that's for the later '97-'04 models, but if you don't get an answer about yours specifically, that might get you in the ballpark at least.
Good luck.
Paul
derwochi Oct 12, 2012 07:02 AM
Hi,
thanks for this.
To tell from the force I had to come up with while loosening the nut,
I would not expect this to be far away from 55 lbs.
However one can be completely wrong.
But, as you mentioned, 55lbs sounds quite reasonable for what it does.
Take care,
Martin
