-   -   Stall (https://www.buickforum.com/forum/regal-1973-2004-23/stall-322/)
cellulargod721 Mar 4, 2006 12:19 PM
OK here it is 92 Regal 3.1l
Every so often just coming off of idle my engine will stall. It starts right back up and then wont do it again for a while. It runs flawless otherwise(no missfire or bogging). It has 144'000 miles on it fresh tune up and fuel filter and pump. I am very confused cause there is no rhyme or reason to this besides only when you got to accelerate off of idle.
Erakiel81 Mar 4, 2006 02:57 PM
have you checked the EGR valve ?
SSEBonne90 Mar 4, 2006 09:00 PM
Intermitten stalls are most likely caused by a bad / dirty connector to a sensor or module.
Try removing the ICM connector and clean and tighten up on the sockets.
Then procede to the rest of the sensors if it still happens.
Also a dirty IAC valve will cause a decel stall.
