I have a 1994 Buick Regal custom. The battery has been running low and I've had to jump it a few times. The speedometer recently stopped working. It goes all the way to 100+ and stays there. Is this because I need a new battery or alternator or ? Please advise. Thank you in advance. |
I have never seen that happen, but many crazy things can happen if circuits don't see a consistent supply voltage around 12 - 14. Also, the surge from a jump can sometimes damage electronics.I would suggest you get your battery / alternator fixed as soon as possible.Edited by: MrBSS
Thank you for the quick reply. Do you know if I put in a new battery, the speedometer will go back to normal or do you think it's shot? |
You probably should check your charging system (alternator, grounds, etc.) to be sure its not more than just a worn out battery. If I had to guess, I would probably say the speedo is shot, but why not fix the first problem and see what results? |
Hi!
We are all familiar with this reality that this is the world of the inventions and information.New and the latest scientific information are available for the betterment and the progress of the Human beings.But if any guy who may not feel satisfaction then he should immediately make a contact with the great company inventions. |
| All times are GMT -5. The time now is 05:53 AM. |
