-   -   I need a link for 3800 intake torque specs (https://www.buickforum.com/forum/regal-1973-2004-23/i-need-link-3800-intake-torque-specs-6026/)
brimmer555 Jan 7, 2012 05:29 PM
I need to know what the torque specs are for the upper and lower intake manifold bolts are.
Anyone have a Link for me?
it's a non-supercharged 2002 Buick Regal 3800.
Merc6 Jan 7, 2012 07:51 PM
I have the specs at home in my Century service manual. It's funny how they add the 3800 II teardown specs to a car that didn't have that engine. Will post it and pics around 12:00 Eastern Time when I get home. There was teardown and order to tighten.
brimmer555 Jan 8, 2012 12:02 AM
Awesome. Thank you. I broke down an bought the haynes manual for the regal, but I would like to know if its the same specs.
Merc6 Jan 8, 2012 07:36 AM
Should be if it has 3800 engine in the book. Century/Regal are same car but they don't have the same engine. Depending where you go they assume the Century has a 3800 II option. No 90 Degree V6 engine comes in a Century from the factory.
Pattern
http://i90.photobucket.com/albums/k2...6/e6693881.jpg
Upper
http://i90.photobucket.com/albums/k2...6/b5b31e99.jpg
Lower
http://i90.photobucket.com/albums/k2...6/36d396f4.jpg
brimmer555 Jan 9, 2012 03:02 PM
Well I got the job done on the intake only to test drive it and find a big leak coming from a hard plasting 90 degree elbow connected on the passanger side lower intake and sending coolant from the casting above the water pump.
When I was test driving I found that my heater was blowing cold air and the temp gate was reading hot because It had blown out all the coolant on the drive out of the driveway.
Merc6 Jan 9, 2012 03:38 PM
That I was referring to in this post
Originally Posted by Merc6 (Post 11388)
The reason I asked if it was the gaskets was these sometimes go too.
http://shop.zzperformance.com/store/...nt-Elbows.aspx
brimmer555 Jan 9, 2012 07:44 PM
LOL where were you before the GM garage told me that it was that gaskets lol. I just bought those today from NAPA for $4bucks an change.
But now I have New Felpro upper and lower gaskets and valve cover gaskets and I cleaned the throttle body with carb cleaner while it was all apart.
Merc6 Jan 9, 2012 11:48 PM
Glad you were able to get the parts and get it done.
feltes94 Jan 10, 2012 08:30 AM
they would also be posted on napa shop key thats what i used its free and acurate
brimmer555 Jan 10, 2012 11:01 PM
Well I finished the job today. Those new heater tubes were just what the doc ordered lol. the old ones were broke off inside thelower intake, and the block. I poped them out with a flathead screwdriver :)
