-   -   fule gage problems (https://www.buickforum.com/forum/regal-1973-2004-23/fule-gage-problems-5858/)
feltes94 Nov 17, 2011 02:44 PM
fule gage problems
when first start the car it reads empty for at least 5 min then it goes to full and stays ik that the tank is full but i want to know if its because the car reads gas once in a wile i am use to my gage always reading constently
2k2cse Nov 17, 2011 04:28 PM
The gauge reads constantly. You might have a bad sending unit, float, or a bad connection somewhere.
feltes94 Nov 21, 2011 09:59 AM
ok but for some reason it works when car is off and only when key is in on but when car running doesnt work
hanky Nov 21, 2011 02:56 PM
Might be a good idea to check the ground circuit for the gauge assy.
feltes94 Nov 30, 2011 09:58 AM
i am just going to replace the whole thing because i have to work on lot of things i have dripps from my oil pan
feltes94 Feb 15, 2012 03:00 PM
i put new fuel pump in and now everything works perfectly
Merc6 Feb 16, 2012 10:33 AM
Which brand did you get?
feltes94 Feb 21, 2012 03:02 PM
i went threw napa i not really sure what brand by dad got it for me
huey286 May 10, 2012 02:06 PM
Can't find where to start new thread, so will post here. 98 Lesabre pcv valve from O Reilly pulls too much vacuum thru crankcase, and sucks oil thru intake. oil goes down too fast, and if remove oil filler cap, eng slows like big vacuum leak. I'm told only AC Delco valve works right in these 3800's. will try one for $8, only from dealer. all after-market ones must let too much air thru. Is that right? huey286
