Bights,Blinker stick
so i need to replacer the stick in the 200 buick regal that controlls brights blinker and cruz how hard will this be to change for an unexperenceed person? and should i buy new or go to junk yard to get one?
You would be better off getting a new one. If you get used, then you might end up with one that has the same problems, or will soon. It might be a little difficult for someone inexperienced. There should be a write up somewhere on how to replace it.
alright thanks
well i got the new one for $65 off ebay brand new it was way better buy then from gm or napa for some reason and it only took 10 min to install i am very happy now all i got fix is overdrive problems
| All times are GMT -5. The time now is 01:02 AM. |
