-   -   abs problems on a 92 regal ltd (https://www.buickforum.com/forum/regal-1973-2004-23/abs-problems-92-regal-ltd-2474/)
kevinham013 Mar 24, 2009 04:57 PM
i recently changed my front brakes and ball joints,,when I changed my front brakes all I did was use a c clamp compressed the caliper cylinder and then replaced with new brakes,,(not loosening any oil lines).while compressing the calipers it pushed oil out of the resevoir ,,not all done I started the car pumped the brakes up to normal,,and now my abs light wont go off,,any ideas what I have to do to fix this,,thanks!!
ty95yj Apr 2, 2009 01:55 AM
mine is on also. i need new calipers or an abs sensor. im not sure 100 percent what it is. hopefully i get it fixed soon. once i do ill let you know what the problem is
