ABS light, srvc vhcle soon n trac off
Old 02-11-2008, 07:13 AM
BlackLuve's Avatar
I HAVE A 1999 BUICK REGAL GSE. WITHIN THE LAST 3 WEEKS, I'VE HAD TO GET A FULL REAR BRAKE JOB, NEW TIRES AN ALIGNMENT ALL GASKETS REPLACED AND FLUIDS DRAINED. I WAS TOLD AT THE SHOP THAT I DIDN'T NEED FRONT BREAKS BUT WHEN I DRIVE (NOT ALL THE TIME), THE ABS LIGHT, SERVICE VEHICLE SOON LIGHT N TRAC OFF LIGHT WILL COME ON, THEN I HEAR A GRINDING NOISE FROM THE FRONT OF THE CAR. I CAN NOT AFFORD ANOTHER EXPENSIVE FIX! 1200.00 TO THE DEALERSHIP AND 600.00 TO THE BRAKE N TIRE SHOP.
Old 02-11-2008, 09:02 AM
garllo's Avatar
I had to replace a front wheel bearing on my 2000 Regal. That is a complete assembly , hub, bearing , ABS sensor. If there is a problem that could cause the light to go on. I would also check the connection at each wheel. It's a starting point !
Old 02-11-2008, 06:09 PM
BlackLuve's Avatar
Thanks! I will def look into getting the connections checked first and work my way up.
Old 02-13-2008, 06:55 PM
BlackLuve's Avatar
IT WAS AT THE DEALER AGAIN TODAY. ALL TESTS AND SCANS THEY DID TESTED OKAY. THEY DROVE THE CAR FOR ALMOST 20 MILES N THE LIGHTS CAME ON NOT ONCE!! I GO TO PICK IT UP AND DIDN'T EVEN GET OFF THE DEALERSHIP PARKING LOT WHEN THE LIGHTS CAME BACK ON. I ALSO NOTICED THAT WHEN THOSE 3 LIGHTS COME IT, IT CHANGES THE READOUT ON MY MILEAGE/OIL LIFE GAUGE. IT WILL GO FROM SHOWING ME MY MILES PER GALLON TO SHOWING MY OIL LIFE. I'M SO CONFUSED AT TO WHAT IT COULD BE!! I NEED HELP/SUGGESTIONS FAST!
Old 03-31-2008, 03:41 PM
violators's Avatar
It deffinetly sounds like the hub assembly,mine did the exact same thing,I replaced it and everylight turned off,now when I beat on her a bit or make a sudden stop,it goes back on,I turn the car off then on and its gone??time to replace hubs
CSAC
03-31-2015 09:18 AM
kevinham013
03-25-2009 09:14 PM
allbabeatt
11-08-2008 07:42 PM
schellmis
04-10-2005 05:31 PM
Quick Reply: ABS light, srvc vhcle soon n trac off
