Hey there everyone, i have a question about my 1999 regal ls (it has the 3800 series II v6, not supercharged). I noticed that the front passenger side floor is always wet. I followed the trail of water that was leaking from under the glove box area. There is a black hose connected to a metal cylinder kinda behind the glove box. The hose gets disconnected and leaks what i hope is water. I was wondering if anyone here knows what the hose and the cylinder are, or what it is leaking, or how I could fix it.
I hope this is enough information, thanks in advanced ~Matt |
Hello
I also have a 99 Regal but mine is supercharged I have the almost the same issue as Matt i.e. the front passenger side floor is wet but only when it rains. It has been raining quite a bit lately. I found a puddle of water on the front passenger side floor. Any thoughts on a solution would be appreciated thanks. MJF |
That hose could well be from the AC, look under the car for the condenser drain hole and make sure it''s not stopped up. The easy way to do this is to take a piece of wire and just run it up through the hole, or from the top down. I''d start there.
| All times are GMT -5. The time now is 06:04 AM. |
