-   -   1999 Regal Dashboard Back Lights INOP (https://www.buickforum.com/forum/regal-1973-2004-23/1999-regal-dashboard-back-lights-inop-1449/)
JetTech Apr 19, 2008 04:53 PM
All my dashboard back lighting is not working I have checkand replaced thefuse but this has been no help.The caution-warning lights & odometer are working normal. Any ideas on what may be the cause. Thanks Edited by: JetTech
grant Jun 7, 2008 01:34 PM
I had the same issue with my 2000. I bought a used headlight switch on
FleaBay for 10bucks and that''s all it was. I figured
it was the switch because one night I tried wiggling it and saw the
lights flicker.
It''s easy to swap out too...the panel beside the switch just pops of and you can reach the switch through an opening.
good luck!
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
