My left brake light is out. I already changed the bulbs, and I also checked the fixtures to see if they were getting power. They are. Does anyone have any suggestions? |
you said that you checked for voltage, where did you ground your lead? it could be possible that you have a bad ground at that socket (or side). do you have a multimeter (that you can check resistance) with (to see if you have a good ground)? g/l - sos |
