94 Regal Custom Keyless remote
Old 08-08-2013, 10:15 AM
Thores Stone's Avatar
Default 94 Regal Custom Keyless remote
Just got a pretty decent shape 1994 Buick Regal Custom from my girl friends father after my Mazda Protege just crapped the bed. He had a keyless remote but I dropped my keys and they fell into a sewer drain. Luckily I only had my car keys on it and not all my keys.
I got a new key made and I just bought a keyless remote off eBay. I've searched for a hour or two trying to find instructions on how to program this new one. I've found several different ways and not one of them has worked. Then I found one that you have to use the programming connector in the trunk. Couldn't find a video of how to do this method. Tried finding the wire but wasn't sure which wire it actually was.
Does anyone know where I can find a video to do this, or some sort of picture diagram(actual pictures not veal diagrams)?
Edit:
Forgot to add the remote is a:
Trw
P/n: 10205239
Doc/mdc: 218K1035
Model/fcc ID: ABO0104T
Old 08-14-2013, 02:36 PM
Have you tried to contact the manufacturer. They may be able to supply an instruction manual.
Old 09-21-2013, 08:47 PM
Kiss4afrog's Avatar
Any of these help ??
https://www.google.com/#q=1994+regal...ry+programming
Note: Existing keyless remotes will be erased with this procedure.
Existing working remotes will have to reprogrammed also.
1. Locate the programming connector wire located in the RH trunk area.
You may have to pull back right side trunk trim on trunk wall to locate
the single black/white wire.
2. The programming connector wire should have one termial in the plastic
connector on end of black/white wire. Ground the terminal in the connector
to a nearby bolt or trunk latch.
Leave connector wire connected to ground through out procedure.
3. System will now lock and unlock doors automatically to indicate
programming mode has been activated.
4. Press any button on keyless remote. System will respond by locking
and unlocking doors one time to indicate successful programming.
5. Repeat step 4 for to program any additonal keyless remotes including
and existing keyless remotes. Do not remove ground wire between
programming of keyless remotes.
6. Disconnect programming connector wire from ground to exit programming
mode.
7. Test keyless remote(s).
ShooterD
08-08-2017 09:15 AM
corelite
03-02-2009 09:15 PM
corelite
02-28-2009 10:22 AM
koobiidoobii
11-25-2008 11:37 AM
buik94lesabre
11-25-2008 10:22 AM
Quick Reply: 94 Regal Custom Keyless remote
