-   -   02 regal seat heater (https://www.buickforum.com/forum/regal-1973-2004-23/02-regal-seat-heater-318/)
wrustywrench Feb 26, 2006 06:17 PM
I have a 2002 regal with leather and seat heaters..
the drivers side started to get weak and no longer works....whats up with that??
still has power, and I have swapped the relays and checked the fuses...seem to have no blown fuses and the drivers relay still worked the pass side heater. I do have a rattle in the relay base??drivers side.
is te thermostat bad int eh element,, the relay clicks but no heat on the drivers.. The passenger side works, the relay clicks untill gets up to temp then it goes off like norma...comes on when needed. I assume the therocouple is bad''
hard hard to sway elements and thermocouples....how do I ckeck it or is it sumthin else??
