How To Reset the Engine Oil Life Button on a '07 Rainier
Hey guys,
Do you guys clamor to reset the engine oil life button on your Rainier? Here's a quick guide on resetting the said button! :) 1) Turn your engine off and remove the key from the ignition. Close all the doors in your Rainier. 2) Reinsert the key and turn it to the notch labeled "Run" on the ignition (do not crank the engine). 3) Press the accelerator pedal to the floor three times rapidly (within five seconds). 4) Turn the key to "Lock" for a few seconds then remove the key. 5) You're doneskys! :) |
Mr BuickBag,
Thank you very much for all the repair info you have submitted. Unless one works for a Buick dealer, some of this info is quite difficult to find. Keep up the good work! hanky |
