1965 Riviera project
Old 07-16-2018, 11:28 AM
glaicius's Avatar
Default 1965 Riviera project
Gents, I found a 1965 Riviera project car within a hours drive from where I live in Mississippi. According to the owner, the vehicle runs and drives, and has just a couple of minor electrical issues. The floor pans need to be replaced. Drum to disc conversion has been done. I will be taking a look at it sometime this week. My main question is this: Does anyone know of any particular areas associated with this year and model that one needs to pay close attention during inspection? I already know to look at the rear low quarters, below the windows and trim, rocker panels, and all the weatherstripping area.
Thanks in advance for any input given,
Marc
Old 07-18-2018, 03:03 PM
A lot is going to depend on where the car spent it's days/years and how well it was maintained. They don't build them like that anymore.
Old 07-24-2018, 07:34 PM
glaicius's Avatar
Default It's mine, finally!
I was able to inspect it. Solid with little rust. It is a total project, though. Minus the engine and transmission, it'd take me 2-3 years to get it where I want it to be. After some bargaining, we settled on $6000.
Old 07-26-2018, 08:05 AM
Nice , really great shape !
Old 07-27-2018, 04:12 AM
Roger that on condition. Would be the time to decide if the resto would be back to original, modern upgrade or performance retro. Imagine popping the hood on that with a GTO 3-2 barrel carb setup? https://www.hotrodders.com/forum/thr...es-171673.html
Old 07-28-2018, 08:35 AM
glaicius's Avatar
As of right now I'm sticking with the original. Although, a LS1/2 has crossed my mind.
Old 08-02-2018, 09:05 AM
Speaking of two carbs,
Did you know that Buick in 1941 had the straight 8 engine with 2 carbs as original equip ?
Old 08-02-2018, 12:54 PM
No, I never knew of the straight 8 even until I bought a '49 diecast 1/18th Roadmaster. Those must of had incredible torque capabilities
  #9
Old 08-03-2018, 06:57 AM
They were some vehicle, the antenna was in the center front of the roof, and and you could rotate it and set it down, The Special and Super had 3 vent holes in the front fenders while the Roadmaster had 4 holes.
I believe Buick came out with the Dynaflow Trans in 1950 or 51.
In 1953 the GM Hydramatic plant burned down and Cadillacs were built with Dynaflow transmissions. Gas was a lot cheaper those days . $0.19.0 cents per gal.
As far as the straight 8s , they were very reliable and held up pretty well, just took up a lot of room under the hood and that was probably why the noses of the vehicles were so long.
Gil
11-30-2020 03:06 PM
Joe Veronica Closner
08-29-2019 01:33 PM
vendo
07-18-2016 10:51 AM
65 RIV
09-19-2007 05:54 PM
Quick Reply: 1965 Riviera project
