01 Lesabre driverside front power window don't work
I hate to start A new thread about old topics, but I need some more info Please... My drv door window works when it wants to, this is what I did, I installed A new window regulator w/new motor, tested (used) main switch, tested (used) door module, Checked all the wires in the door, connectors ect. and it still would not work, I can hear the door module click. I drove to town and tried to switch it A few times and it would not work, I pulled it back in to my garage and it started to work. I opened and shut the widow a few times and it worked. It would do this a lot, work then will not work. I'm not sure if the door module has to reset it self or not. The rest of the windows work fine.
Does the switch at the drivers door control the other windows properly? Any corrosion at any of the connectors? You may have a chaffed wire somewhere between the switch and regulator, and isn't making a good connection.
I checked all the wire running to it and all the connectors and they look good, all the other windows work. The only thing I can think of is that the window seams to be A little lose in its track witch I'm going to check that out, you would think I would still see or hear the motor engage and move a little. I'm going to tare it apart Today and mess with it again.
Originally Posted by south of canel
(Post 14097)
Don't give up just yet.
To clarify for my own understanding, you say you have power to the motor. When you are using the switch do you still have 12 volts going to the motor and are there any times you have power to the motor and the motor does not respond? Are you checking for power (12 volts) to the motor at the time it will not work? If that is the case get another motor. If you have confirmed that the ground for that motor is good and solid and you have power to the module and none to the motor the module has a problem. With the door open , can you move the wires at the hinge area and see if you can cause any change. wires do break in there many times due to the constant flexing. |
Originally Posted by hanky
(Post 14099)
| All times are GMT -5. The time now is 04:10 AM. |
