2010 lucerne rear fuse panel
1 Attachment(s)
Does anyone have a photo like the one attached that would show ALL the wires in their proper location on the rear fuse panel. The fuel pump relay burned out (pin location circled).
Not knowing your level of expertise , even a diagram is going to be tough to correct the problem , especially if the wires actually separated.
Can you handle knowing how to determine which terminal of a relay, for example, does what? Can you fill me in on this? |
| All times are GMT -5. The time now is 11:41 PM. |
