-   -   where is my fuel filter located?? (https://www.buickforum.com/forum/lesabre-24/where-my-fuel-filter-located-1141/)
Jeremy Sep 7, 2007 01:34 PM
Help, I need to change my fuel filter and I can't find it. Does anyone have an idea where it is located on a 1993 le sabre.
thanks
jerald120374 Sep 9, 2007 06:01 PM
I have 1992 LeSabre and the fuel filter on the '92 and '93 might be in the same place. Jack up the car and crawl underneath it behind the right front tire and look up.On the '92 there is a cooler for the power steering fluid almost right next to the fuel filter. If this is the correct place, you will probably find it easier to remove the cooler in order to get the filter disconnected. Hope this helps you
Jerald
samueljackson Sep 19, 2007 05:49 PM
find it?
