-   -   What scanner do I use (https://www.buickforum.com/forum/lesabre-24/what-scanner-do-i-use-6766/)
VanBuren Sep 9, 2013 05:47 PM
I can't find any clear cut information on what scanner code reader I should use on my car. It seems that my 1995 LeSabre is in a Gray area when it comes to whether or not it is OBD II. Can anybody expound on this?
hanky Sep 11, 2013 07:23 PM
Look at your Data link connector under the dash.
If it has 12 pins it's OBDI . If it has 16 pins it's OBDII. That was a tough one, good to see you back !
VanBuren Sep 12, 2013 03:19 PM
Hey Hanky, Thanks. I know mine is a 16 pin and is there a way to do this with a paper clip.
hanky Sep 12, 2013 05:03 PM
No , not with OBDII. Must have a code reader or scan tool.
VanBuren Sep 19, 2013 01:38 PM
OK. I went to Advance auto and they plugged the reader in and basically the reader accepted the plug-in and got to the point where it says it's "Working" and then after a minute, it says Link Error. So, the next thing I did was to go to AutoZone and I got the same results with them. So, I am baffled.
2k2cse Sep 19, 2013 04:32 PM
Maybe it's OBD1.5? I believe they had an OBDII connector, but worked like OBDI.
