-   -   Scanner for codes, 94 LeSabre (https://www.buickforum.com/forum/lesabre-24/scanner-codes-94-lesabre-800/)
big bug Mar 12, 2007 04:44 PM
Hi all,
I want to purchase a scanner to read & clear the codes of the car. Is the 94 Le Sabre OBDII compatible? Which scanner do you suggest I buy? Make, model.
Thanks
Doug
bassasasin Mar 12, 2007 11:06 PM
No... OBD1 usually.. I hear there are some that have the OBDII but you must count the pins... or have it checked at a parts store..
They are usually OBDI with a OBDII connector..
GOOD LUCK
big bug Mar 13, 2007 05:13 PM
Thanks man appreciate your help
