-   -   Replacing AC compressor (https://www.buickforum.com/forum/lesabre-24/replacing-ac-compressor-202/)
buckroo Nov 2, 2005 01:53 PM
Just how much trouble is it to replace the AC compressor on a 1995 Buick LaSabre with the 3.8 v6 engine? I am generally considered mechanically inclined as I do most all my work on my cars and I also have a certification for ac repair. Is there a site that gives step by step for replacing the compressor? Any help will be appreciated.
Patrick Nov 2, 2005 07:26 PM
i dont know of a step by step, but i dont think that it should be that hard. do you have a recovery system?
buckroo Nov 2, 2005 10:21 PM
I really don't think I need one since there is no freon in the system but I do have a vacuum.
Patrick Nov 3, 2005 04:45 PM
in my experiences, the AC compressor is usually the last item to go on, thus making it the easiest...but that certainly doesnt apply to all vehicles.
buckroo Nov 10, 2005 01:42 AM
Well it may be easy for some folks but I have been under the car and I don't see anyway to get the unit out from the cross members and other things.
sdsdsd Dec 13, 2005 02:49 PM
It is not an easy job I would rate it 8 on a 1-10 scale
SSEBonne90 Dec 25, 2005 11:32 PM
not as bad as a 90. Just replaced my 90 compressor.
Hardest problem is lining up the top bolt.
Series II was re-designed and has easier access.
Patrick Dec 27, 2005 11:18 AM
wow..its under the car? well then, i apologize, that woudl make it quite a bit more difficult...
SSEBonne90 Dec 29, 2005 12:27 PM
under pass front near rad.
