Hi, I need help removing passenger side door panel. I don't see any visible screws and I know it's not good to just try and pry it off. Thanks for help in advance.
well, you might want to check your car's manual.. you can find them lots of diffrent places. But there are no screws they are clips and yes you do just pry them off, but one ata time and with a special tool, you can usualy get away with a straight slot.. start in the seam where the pannel meets the metal.. I know it's a little scary at first but once you get the first clip off yit'll make sense.
Thank you very much for the info. I got it no problem :-)
| All times are GMT -5. The time now is 05:44 AM. |
