-   -   Problem with 1995 heat (https://www.buickforum.com/forum/lesabre-24/problem-1995-heat-1400/)
da_crash2000 Mar 24, 2008 03:46 PM
I just bought this car the heat only worked on high or not at all and it was hooked up to a relay. He said that before he added the relay the fan ran 24/7 and that the problem was a module that went out and it common in many GM products. My problem is I can't figure out what its called. I have no clue what part I am looking for but I guess it was originally a $700 part and now you can get it for about $200. So if anyone knows the name of the part and how easy it is to replace it would really help me out
samueljackson Mar 24, 2008 05:16 PM
have you tried the coolant temp sensor?
if you have a repair manual, and a multi-meter, you can test it. but its only a 10-15 dollar part if not.
