Hello everyone I just bought a 2002 Lesabre Custom I thought the Power Door Locks where working Ok then I noticed that when I press the key FOB it only operates the driver side door When I put the car in Drive it only locks the drivers side door and when I put the car in Park it only unlocks the Driver side door the other doors seem to be dead and only work manually the LOCK/Unlock button does not work on the doors on either the passenger side or driver side I am using Key fob #2 and it I have tried to different ways of reprogramming the door button opening with no luck Any ideas what I need to do to fix this my biggest fear is a body control module Please help Edited by: prostude |
Well I just drove it to work and realized that the Power Windows are not working at all along with the door locks not working even though they where working yesterday I have owned this car for a whole 2 days |
Originally Posted by prostude
Well I just drove it to work and realized that the Power Windows are not working at all along with the door locks not working even though they where working yesterday I have owned this car for a whole 2 days check the fuse. |
After work yesterday got out and everything was working By the time I got home it was not working again Checked the ground checked for wire problems between door jamb Anyother ideas? I assume it is not a fuse since it did not work then it worked and is not working again[img]smileys/smiley6.gif[/img] |
After work yesterday got out and everything was working By the time I got home it was not working again Checked the ground checked for wire problems between door jamb Anyother ideas? I assume it is not a fuse since it did not work then it worked and is not working again[img]smileys/smiley6.gif[/img] ok open drivers door and check the wirers there. |
| All times are GMT -5. The time now is 09:15 AM. |
