Lesabre Harmonic Balancer Removal
Hello,
Thanks for the great forum and for the help! I have a 1994 Lesabre that I suspect of having a faulty crank position sensor. I'm trying to remove the crankshaft pulley \ harmonic balancer \ vibration damper \ whatever you want to call it. I've put some serious torque on that bolt holding the pulley on, and I cannot get the darn thing to budge. I've tried an impact wrench, that didn't do it either. (The wrench only goes to ~250 ftlbs or so) Anyway, I am assuming that it is a regular thread nut, so I am turning it left to remove it. I know sometimes these pulleys have a reverse thread nut on them, does this happen to be one? Anyway, any advice on removing the darn thing would be great! Thanks again. |
Buick Lesabre
Hey I am new on here and i read your old reply about the harmonic balancer! We have did the same thing you mentioned. Impact, and even coming up with various ideas with absolutely no results! I see that was over a year ago! Could you email me at kiss_creatures@yahoo.com and share your findings with me! I would be sooooo grateful!
thanks Greg |
Hi,
I eventually just gave in and took it to my mechanic. He put it up on his lift where he had room to put a 5 foot cheater bar on it, and was able to get it off. It was really on there tight, though. Good luck. |
I had the same problem a few months ago. It is a regular thread. I used an air impact, and just kept at it. Don't forget, once you get the bolt out, you will need a puller to remove the harmonic balancer. Good Luck
You are going in the right direction to remove the bolt. Get yourself a 3/4 inch drive, bar and socket with a 3 foot pipe and that will get it loose.
| All times are GMT -5. The time now is 11:32 PM. |
