Swapped computer and prom over, volt light is off now still have the SES light however and the car still don''''t down shift. Any clues or tips, the car still runs great and goes in all gears just no kick down got the cluster with all the gages, go figure this would be one of the few GM''''s thats not plug and play, has anyone ever swapped one out with the basic speedo and fuel gage and got it to work? if so what all do we need to change to get it to work besides the oil PSI sensor Thanks for any help, Donnie H. <! Signature > Edited by: tosun28 |
.Edited by: tosun28
more info please. what did the donor cluster and pcm come from? bc, 94-95 H and C body pcms arethe only "plug and play" for for car listed in your sig. |
94 and the same car as mine even down to the color as well. When we plug the cluster in it blows the fuse that runs the ac control panel/dome light switch, but the dome lights will still work if the doors open "weird"
maybe the junk yard cluster is defective. you should have no issues with the same year. for the pcm, did you swap the prom from the original pcm? |
DOH! just saw the first line in your original post, you did swap the prom. |
| All times are GMT -5. The time now is 04:59 AM. |
