I have a 92 Buick Lesabre, I am having trouble with the brake on this car. I only have brakes on the front drivers side and the rear passangers side. My pedal goes to the floor (very little stopping power). Rear brakes are ALL new I replced every pcs. I tried the master cylinder but fluid comes out both sides (front and back holes). Any help would be appreciated. Yes I have bled the brakes multiple times (wasted1 gallon brake fluid). Thank You. |
Might still be the master cylinder. Sounds like one side is bad or at least leaking under pressure. Also, a master usually has to be bench bled if air has entered. Another possibility is in the ABS system. |
Possibly air got in the Master cylinder. </font> Can you ever pump up your brakes at all? Are you leaking any fluid?<br style="font-style: italic;"> </span>If you can, does the pedal continue to fade down after it becomes hard?</span> Proper bleeding can be a nuisance, Here are my notes. Try my checklist. </span> </span>Pumping pedal is slowly but firmly. DOT 3 brake fluid. <ul>[*]If there is suspect air in the master cylinder.[/list]Bleed Master Cylinder. To bleed Master Cylinder <ul>[*]Never allow the reservoir to empty below half.[*] Open the front line and fill till fluid drains without air.[*]Reconnect line and close and tighten the line to 24 ft lbs.[*] Get an assistant to slowly press the pedal while cracking the connection and checking for air.[*]Wait 15 seconds and repeat.[/list] Apply this process for the rear master fitting. </span>Bleed the wheels in proper sequence. </span> Follow the sequence for the wheels according to body type. DOT 3 brake fluid. Never reuse brake fluid. Never allow the reservoir to empty below half. Bleed sequence depends on BODY Type VIN# Yours is LeSabre.. Checking it shows sequence.
Edited by: bassasasin |
| All times are GMT -5. The time now is 05:02 AM. |
