-   -   Another Climate Control Problem (https://www.buickforum.com/forum/lesabre-24/another-climate-control-problem-6488/)
VanBuren Dec 11, 2012 07:19 PM
Re: '95 Bu LeSabre. 4dr Limited w/climate control. I just found a solution to the problem of not getting any air coming out of the dash vents with the expert help of Hanky. The problem that I have now has to do with hot air coming out of the driver's side vents but cold out of the passenger's side. As it turns out, I can manipulate that by moving the linkage/lever on top of the heater/ac housing.( of course after getting the glove box out of the way) Something that controls the action of that door has gone awry. Where can I look what can I do and where? Thanks. Zuko
hanky Dec 11, 2012 07:28 PM
Since those parts I believe are vacuum controlled, look for a vacuum line that might have come off.
VanBuren Dec 11, 2012 09:55 PM
Hi Hanky.
Come to think of it, that little square vacuum manifold with all of those tubes connected to it does have one male port that doesn't have anything connected to it. I just thought it was one that just wasn't being used. When I first saw it, I looked around for a tube that might have come off, but I couldn't find any. Other than that, if that's not the one, would the tube that might be off be inside the box or outside. Bob
