AC actuator/blend door problem?
Hello newbie here, my recently purchased 05 Lesabre has cold air blowing on the passenger side upper vents but the drivers side vents are blowing warm air, I have found 2 actuators but they are obviously not the one I'm looking for any help locating that rascal will be greatly appreciated THANK YOU
Under black panel on pass. side, below glove box. Remove black panel and it will tucked up inside.
I have already found that one and its working fine I also found the one opposite of it but neither control the drivers side ac vent ...please help
Those are the only ones. Are you sure it's not the control panel itself? Is this a limited or custom?
Hello I thought there was only two of them, it is a custom thank you for your response
Have u checked out YouTube vids? May find an answer.
There are times when you need to remove the glove box to get access to the ductwork and actuators Not that difficult to do.
Hanky is right!
| All times are GMT -5. The time now is 09:50 AM. |
