-   -   99 lesabre, not starting, any ideas? (https://www.buickforum.com/forum/lesabre-24/99-lesabre-not-starting-any-ideas-2823/)
avoyager Aug 19, 2009 09:11 PM
Even with a jump, my 99 lesabre won't turn over.
I removed, cleaned, reassembled, and tightened the battery connections.
Battery seems strong.
When I turn the key, all the lights blink about every second continuously.
It's very strange.
I've had lots of dead batteries over the years but this behavior has me baffled.
I get the same result whether or not I'm jumping the vehicle.
I use very large jumper cables connected to a chevy venture (which I think has plenty of amps to spare).
Any idea's on what might be the problem?
Or, what to check next?
Thanks!
avoyager Aug 20, 2009 08:30 PM
This problem was resolved by replacing the battery w/a new one AND thoroughly cleaning the cable connections to the battery.
Someone had posted a reply on this topic but it's now missing.
That person suggested shorting the solenoid on the starter (thanks for the tip!).
This I did and the engine tried to turn over but failed due to lack of power.
As part of the new battery install, I pulled all the rubber boots off of the red cable connectors and found lots of corrosion. I thoroughly cleaned off the corrosion and sprayed anti-corrosion onto the parts before reassembling.
Starts like a champ again.
93Lesbre Aug 30, 2009 06:16 PM
glad that worked
