-   -   ’95 la sabre dies in traffice, HELP (https://www.buickforum.com/forum/lesabre-24/95-la-sabre-dies-traffice-help-207/)
m-smitty Nov 4, 2005 06:22 PM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
My '95 la sabre arbitrarily dies in traffic, usually at a 35-45mph--sometimes I'm pulling a slight grade--6 miles into warm-up. My power steering unit is 'whining' but seems to work okay otherwise. There is some hesitancy in engine, I just had the crank sensor replaced. Anyone with past experience with this problem? I know I should have it put on computer but right now I cannot afford major repairs.
Erakiel81 Nov 6, 2005 06:00 PM
If it's only when your car is hot try to unplug the EGR valve.
Search on this forum for EGR valve, you will find many info.
sdsdsd Dec 13, 2005 02:50 PM
Most likely the computer or mass air flow sensor
kelcra259 Dec 13, 2005 03:00 PM
I will go with above comments including vacuum lines. Cheapest and easiest way to fix engine "dying" problems.
SSEBonne90 Dec 25, 2005 11:29 PM
Check the ECM and ICM electrical connectors.
Sounds electrical to me.
Also when it stalls check for injector pulse at the connector.
bassasasin Jul 26, 2006 10:47 PM
Stalling Bad gas.. Ignition Module.. Sensors. Grounds, EGR valve, FuelFilter.
Definately check codes.. for free at a Popular Parts store.
Whining Power steering is pump noiseAir in system or Bad pump.Fully turn the steering wheel from completely left to completely right. If thenoise reduces its proubbly just air.IF not.. replace pump. and cycle steering again to escape air.
