| Sweeper11 |
Oct 1, 2006 04:54 AM |
What is the car doing that you need to pull the codes? might help you get replys. but you have an OBDI Pre 1996, cause after 1996 everything is OBD II, codes, there really is no system to the type I codes meaning they really didn't know what they were doing I heard. There is codes somewhere on the internet keep looking.Also I heard by word you canuse the two pins on the upper left but A/B-This did not work in my case on a 1995 park ave though. Also if you disconnected the battery they are lost and this will not do you any good. OBD II reader are easy to buy at auto stores but none carry OBD I found to pre dated I guess. Danger Zone can read them (II) if yo bring the car up to them but some tell you the check engine light has to be on first meaning otherwise you have no codes. hope this helped.
