3.8 cam position sensor,91 lesabre
how do you replace the cam position sensor on a 91 lesabre,3800?
i am getting code 41, and am having hard starts. i have to floor it to get the car to start and then it runs rough and will stall at stops until it warms up. joe:confused: |
There is a 3 wire sencor bolted to the front cover of the engine,use a 10 mm socket to remove the bolt,unplug wires and wiggle sensor up and down to loosen it and remove.
| All times are GMT -5. The time now is 01:39 AM. |
