-   -   2005 buick lesabre starter problem (https://www.buickforum.com/forum/lesabre-24/2005-buick-lesabre-starter-problem-8090/)
joey gossage Aug 27, 2018 09:21 PM
The stock buick lesabre starter bendix won t kick out but motor turns.
Have you ever experienced it ? Is it defective and is there any way to repair it ?
By the way,I find the cheapest 05 buick lesabre starter for sale at Hexautoparts.com only $36.00 with free shipping!
It shocked me.Just think about it.
fabiola perez Aug 29, 2018 01:40 AM
Before you consider buying a newbuick lesabre starter from the Hex you mentioned,you should do more test carefully.
Is it the Battery, Alternator, spark plug or Starter Problem?
You could check as follows:
1. Dead or Weak battery
2. Poor electrical connections at battery terminals
3. Park or Clutch Switch is Broken or Misadjusted
4. Security System Error
5. Damaged Starter
6. Fuel Delivery Problem
7. Spark Issue
Hope that helps.
hanky Aug 29, 2018 02:27 AM
Joey,
If you are going to depend on this car, why would you be willing to install cheap parts in it?
Are you going to do the change yourself or have someone else do it?
