-   -   2000 lesabre (https://www.buickforum.com/forum/lesabre-24/2000-lesabre-6226/)
juggalo41 May 8, 2012 12:49 PM
2000 lesabre
Hey all. new to forum but I am familiar with them. I have a 2000 lesabre limited. I have noticed a pronounced clunk when tapping brakes. It deffinately is from the front as i feel it in steering wheel. I am thinking tie rods but someone said the cv joints could be bad as well. Has anyone had anything like this?. my drivers side tire had worn bald on the outside edge of tire to the point of it splitting. Can someone point me in the right direction. I am doing a rotor and brake replacement this weekend but would like to just do it all if I get info. Thanks
hanky May 9, 2012 03:10 AM
The condition where the tire has worn on the outside would not usually be caused by a tie rod end, but either a worn suspension part or a needed alignment.
The fact that you are getting the clunk would indicate a badly worn part like a ball joint.
A thorough check of the suspension is in order.
29BuickRoster Dec 3, 2012 01:46 PM
Just joined this site....
Just joined this site....and just brought a 2000 Lesabra...maybe this info will help someone from this date on ....I had the same noise and had a mechanic look at it ....said the passsenger control arm was shot...he advised me me to replace the drivers side as well even thou it was ok....
aaronjay345 Jan 29, 2013 05:22 AM
