-   -   1999 buick lesabre makes bad noise when backing up (https://www.buickforum.com/forum/lesabre-24/1999-buick-lesabre-makes-bad-noise-when-backing-up-8376/)
oldfarmboy Nov 5, 2019 10:14 AM
my 1999 Buick LeSabre makes a loud noise when backing up , this has just started , please help , something is not right
Rich B. Nov 5, 2019 04:37 PM
If rear disc brakes, could be a stone lodged in-between rotor and pad. Sounds like a wiped out wheel bearing.
hanky Nov 5, 2019 05:29 PM
Is it possible for you to have someone either drive the car or get close enough to listen for where the noise appears to be originating ? Left rear, right rear. ?
Could involve brake system parts. Helps if the area can be determined to save time and trouble of removing and checking everything.
