2003 LeSabre Overheating
Old 02-22-2017, 08:21 PM
2003BuickLeSabre's Avatar
Default 2003 LeSabre Overheating
I have a 2003 LeSabre with 110,000 miles. Lately the temp has climbed to 220+ degrees when driving slow, such as in traffic. What are some typical things to look for in this vehicle? The car is new to me, bought used about a month ago.
Old 03-01-2017, 04:40 PM
Nobody answered here yet? Things to check are coolant level and quality, belt tension that drives water pump/serpentine belt, thermostat of coarse, radiator may need flushing. Start with easiest checks first.
Old 03-15-2017, 09:57 AM
krankshaft's Avatar
Running hot in slow traffic is generally an air flow issue. Things to check: coolant level, stat,rotted, clogged radiator fins and proper operation of the electric fans. If you have access to a scan tool, you can see the actual temperature which is being sent by your CTS to the ECM.
Old 11-11-2019, 10:47 PM
Frampton1007's Avatar
My car never has gone above 228 and that's in hot summer in stop and go traffic. Thermostat or waterpump maybe....
kianme
02-15-2022 06:50 AM
John Pacyna
12-06-2017 04:27 PM
kdmitchell2776
08-01-2017 06:22 AM
kianme
05-27-2015 04:02 PM
fenwickdrummer
12-07-2006 12:53 PM
Quick Reply: 2003 LeSabre Overheating
