1995 Buick Lesabre 3.8 V6. Need help with removing the timing chain cover, leaking an
Hi guys,
I have an antifreeze leak in my 1995 buick lesabre. I changed the water pump and gasket thinking thats where the leak was coming from. Last year I changed the upper and lower intake manifold gaskets. So I've washed everything down and found that the antifreeze leak is showing up at the corner of the oil pan gasket under the timing chain cover. Now I did put on thread sealer on the longer water pump bolts but I do believe the gasket for the timing chain cover is leaking. The antifreeze leak is NOT coming from the new water pump gasket. I need help with the process of getting to the timing cover, I know how to remove the side motor mount, jacking up the motor to remove the water pump etc., however I don't know how to remove the harmonic balancer and I don't know if i'm better off buying a new harmonic balancer to replace the old one I take off? Are there a few oil pan bolts that thread into the bottom of the timing chain cover? Any help would be greatly appreciated. Thanks |
Anybody give you an help yet?
Do you plan on doing the work yourself, etc.
no help yet, I will be doing all the work myself. The biggest challenge is removing the harmonic balancer without damaging it....
Describe what you can do and what do you need, so that I can fill in the blanks.
Originally Posted by VanBuren
(Post 15012)
I'm waiting for some ink to feed my printer which I expect to get late today. I will make you some pics from my manuals that might give you answers to your questions. I have a problem of my own that will, to some extent, replicate what you will have to do. I might have to replace my crank sensor which includes removing the balancer and I'm hoping it just might be a connector. Keep mind that the pulley and balancer are together (one) and your biggest hurdle will be taking the bolt out that holds it on. Some guys have recommended an impact tool and of course, the other thing is what's in the book which is a wrench affair that holds the flywheel while you put pressure on that bolt so the engine doesn't turn while you are doing it. That means you will have to jack up the car in front so you can access the flywheel cover to get at the flywheel. The pictures will say a lot.
(Post 15015)
I'm unable to open your image, my computer continues to try to open it but it can't. thank you though for doing this extra work/help for me....
I figured that. I am having an issue with PDF vs JPG. You can't add anything here without going to an image host and I am trying to find the right one. I'll get it.
| All times are GMT -5. The time now is 09:46 AM. |
