The 307 in my 1984 LeSabre is knocking bad, and I have found a 350 chevy motor... does anyone know if it will bolt up to my trans, or should I find a turbo350 trans, too?
just because.... i would get the 350 turbo trans just because of how much stronger that trans really is..
but from my specs it says it should bolt up. i''ve never lined them up tho |
I read somewhere it was a direct bolt on, if you swap transmissions watch your drive shaft length, you may have to get one cut down or made for you.
| All times are GMT -5. The time now is 03:18 AM. |
