’95 Blower Motor Control Module/Resistor
Old 10-04-2006, 02:09 PM
SubieHo's Avatar
The blower motor is not working on my father-in-law's 95 LeSabre
Limited with automatic climate control. The control panel seems to be
working just fine so I'm guessing it could be one of two issues:
1) Blower motor
2) Blower control module
Please share your experiences. Specifically, where are these parts
located on this car, and has anyone had problems with these
components. Thanks.
Edited by: SubieHo
Old 10-04-2006, 03:14 PM
buckroo's Avatar
Which blower are you talking about, the heater or the radiator?
Old 10-04-2006, 04:41 PM
SubieHo's Avatar
the heater --
engine cooling system is fine.
Edited by: SubieHo
Old 10-04-2006, 06:11 PM
bassasasin's Avatar
These blowers have a history..
Check for voltages at the blower.
Good luck
Old 10-04-2006, 07:02 PM
SubieHo's Avatar
I won't have access to the car until Thanksgiving when I go to visit my inlaws.
I am hoping that it's just the blower motor itself -- the control modulator is pricey.
Are the blower motors pretty accessible on LeSabres? On most cars, they're located underneath the glovebox on the passenger side.
I don't have any experience working on these cars so any help or instructions on removing internal trim for access to the blower would be greatly appreciated.
Old 10-05-2006, 01:04 PM
bassasasin's Avatar
Its located mid firewall ... Engine compartment.
Somebook indicationsare that its possible that loose wiring may be the problem and could be an easier repair..
Good luck. Edited by: bassasasin
Old 10-06-2006, 01:31 PM
buckroo's Avatar
[/QUOTE]
Bassasasin is correct that the blower is accessabel from the engine compartment on the firewall.
I looked at mine and it looks like the power is coming from the relay bank that is located on the firewall. You will have to remove the plastic cover to get access to them. I would check the relays for a malfunctioning one. To check which oneyou will just have to trace the main wire from the fan to it distanation. This would be the easiest to check.
Old 10-06-2006, 09:07 PM
SubieHo's Avatar
Thanks guys, I'll check it out when I see them in a couple of months and report back with any news on this issue.
  #9
Old 10-07-2006, 03:24 AM
bassasasin's Avatar
The troubleshooting guide recommends looking for power at the blower speed relay switch.
Settings.
Blower speed relay: REMOVED
Ignition switch: RUN
mode selector NORM
Blower switch: HIGH
Check pin 86 to 85 for Voltage if not check fuse 5D
Check voltage at pin 30 should get voltage.
Anyway theres a start.. without pulling the blower.
Good Luck
BASS
  #10
Old 11-30-2006, 07:31 PM
SubieHo's Avatar
Thanks for the help, guys. Replaced the blower motor, and it now works.
andersson
07-31-2007 07:25 PM
bgisse
05-24-2007 04:23 PM
edeee2
12-24-2006 08:04 PM
edeee2
12-24-2006 07:43 PM
Dave42
05-23-2006 02:13 AM
Quick Reply: ’95 Blower Motor Control Module/Resistor
