Question about Drip from 06 LaCross
I have an 06 LaCross 3.8L CX. Has about 150,000 miles on it. I noticed water under the car yesterday afternoon. I started the car and knelt down behind the right side wheel and saw water dripping from the frame behind and to the outside of the oil pan. I suppose it must be coming from the cooling system. What would be in that area near the firewall to drip like that? I looked all around the motor and and I didn't see any leaks from any hoses. Is the water pump in that area (on the right side) underneath the rear of the motor? http://buickforums.com/forums/clear.gif Edit Post http://buickforums.com/forums/clear.gif Reply http://buickforums.com/forums/clear.gif Reply With Quote http://buickforums.com/forums/images...iquote_40b.png |
Tell us where you are located. If you posted this in December and it's water and not antifreeze then you must be in a warm climate and you had the air conditioner running. If I am correct, then the water is simply condensation dripping off the cool parts of the AC components.
Agreed it is most likely condensation from HVAC system
If it is clear water , yes , condensate . Normal , no problem . ( he could have the defrost on , in winter . )
If it is colored water, probable coolant , not good . If it is oil , what color is it , not good ? God bless Wyr |
| All times are GMT -5. The time now is 08:19 AM. |
