-   -   Code P0401 (https://www.buickforum.com/forum/lacrosse-28/code-p0401-9220/)
Btreads May 1, 2023 04:13 PM
Code P0401
I own a 2007 Lacrosse that I purchased last June with 36K . A few weeks ago the CKL came on. I hooked up my scanner, and it threw code P0401. I pulled the EGR, checked everything and sprayed it full of WD 40. After letting it sit for a couple of hours, I blew it out an reinstalled it. It was fine for about 2 weeks, the the light came on again, P0401. I went through the cleaning process again, same results. The engine runs fine. I am thinking that my only option is to replace the EGR, even though there is no guarantee that will fix the problem. Any suggestions?
hanky May 4, 2023 07:01 AM
Look very carefully and thoroughly at the intake manifold itself where the EGR mounts . Look for any burned through areas.
Btreads May 23, 2023 01:40 PM
So far, I have replaced the EGR, checked mounting for cracks, removed the the EGR intake hose and checked that, removed and checked the PCV valve. When I clear the code, it will return in about 2 days. During this whole time, the engine runs great and never stumbles.
