2014 Lacross engine oil low
I changed the oil and filter and now im getting "engine oil low add oil" message. I added 6 qts if 5w30 synthetic. I know the car has oil in it. but this baffles me. any ideas?
Which engine ?
There must be a sensor . This shows the o-ring . 2014 BUICK LACROSSE 3.6L V6 Oil Level Sensor Gasket / O-Ring | RockAuto Also , check the diagram . GM OEM-Oil Fluid Level Sensor 12639127 | eBay I would first try to locate the sensor . Apparently on the oil pan . See if you accidentally disturbed the sensor ot its wiring . When you changed oil . You might try disconnecting the - battery cable for a few minutes in hopes you can reset the electronics . Best of luck :-) Wyr God bless |
| All times are GMT -5. The time now is 05:36 AM. |
