2005 headlight problem
Hi all,
I have an 05 Lacrosse with a problem in the pass side headlight. The low beam headlight keeps burning out. I pulled the headlight assembly off and found the wiring connection to the bulb is cracked and looks charred. I would replace the connection, but it look to me like it has already been replaced once. Where it is taped together is too far into the assembly to try to replace it again. Can the assembly be taken apart to replace the entire wiring? I'd rather do that than replace the entire headlight assembly. |
