Anyone know the top speed for the CXS? been searching all over and can only find the 0 to 60 and 1/4th mile times..
Also any owners wanna let me know what type of oil and filter you like to use on your car? I just picked up a PureOne filter and Mobil Clean 7500 for my first change.. |
well, one thing that i can tell you, i would never trust that "change your oil every 7500" crap...i run synthetic in my car.
Is it true that most Buicks are limited at 108? I read a post somewhere about that..
I'm probably going to run Mobil 1 full synthetic next time, just wanted to use a blend this time because I'm going to do another shorter interval to help flush out the break in metals. I wonder if the drain plug on this engine is the same as the 3800 V6? I'm going to order a magnetic drain plug, but the site I wanted to get it from said Buick hasn't released any info on the size but that all Buicks for the last 10 years have had the same size plug. |
the dealership part dept would be able to tell you if the plug number crosses over to the 3800...as for the speed limiter, that ususally varies model to model...
| All times are GMT -5. The time now is 06:30 AM. |
